Just purchased a 2012 NRS, has V&H slip ons. Not sure if previous owner changed anything else or updated fuel management. I found a set of Rinehart 2 into 2 pipes and plan on having O2 bungs welded in. Will add a K&N air filter and will need to get a tuner. I don't plan on doing any other upgrades, what is my best option?
If that's all you are doing, PV-1. If you are into port welding, put both in for either the newer, heated 12mm and a set beside for 18mm. You just never know at some point you go further and need WB tuning. At least then, you have the ports ready to go.
"Grab your ankles"
Fuelmoto.com
These guys are top-notch when it comes to tuning.
