1 - 2 of 2 Posts
coaltrain
can anyone tell me what the difference in shape is between a 2003 and 2009 radiator if any. Seems the voltage regulator is in a different place but is the shape of the center radiator cover the same?
The radiator is the same but I believe there is a difference in the oil cooler lines (smaller radiator located directly below the coolant radiator). The voltage regulator was only moved on the bikes with ABS since '08 and they located it in the radiator shroud but no difference in the shape of the radiator (it is still a flat rectangle).
1 - 2 of 2 Posts
