PO131 and PO151 are codes that my threw up.I can't fined these codes anywhere.Its was a hot day here yestreday(over40C) and after riding awhile the bike started missing loosing power and backfiring. I have cleared the codes and checked a few things and all seems ok and the bike is running fine now. Does anyone know what these codes are?They are not on the list.
Those are newer DTCs not shown in the list linked in Post #2.
P0131: Front Oxygen Sensor Low / front cylinder lean / signal shorted to ground
P0151: Rear Oxygen Sensor Low / rear cylinder lean / signal shorted to ground
Here are some other newer codes not shown in Max's list
for the turn signal / security system:
B1123______left turn signal short-to-ground (HFSM only)
B1124______right turn signal short-to-ground (HFSM only)
B1125______left turn signal short-to-voltage (HFSM only)
B1126______right turn signal short-to-voltage (HFSM only)
B1136______accelerometer tip-over self-test fault (replace HFSM)
B1142______internal fault (replace HFSM)
B1143______security antenna short-to-ground
B1144______security antenna short-to-voltage
B1145______security antenna open
B1154______clutch switch short-to-ground
B1155______neutral switch short-to-ground
for ABS:
C0562______Device voltage low
C0563______System voltage high
C1014______ECU internal fault
C1017______Pump motor power circuit open fault
C1018______Pump motor ground high resistance fault
C1021______Front wheel speed sensor equals 0
C1023______Rear wheel speed sensor equals 0
C1025______Front wheel speed signal intermittent
C1027______Rear wheel speed signal intermittent
C1032______Front wheel speed sensor circuit open or shorted
C1034______Rear wheel speed sensor circuit open or shorted
C1042______Pump motor open
C1043______Pump motor stalled
C1055______ECU internal fault
C1056______ECU internal fault
C1057______ECU internal fault
C1061______ECU internal fault
C1062______ECU internal fault
C1065______ECU internal fault
C1066______ECU internal fault
C1094______Front brake switch always on
C1095______Front brake switch open
C1118______ECU internal fault
C1121______ECU internal fault
C1151______Front wheel release too long
C1153______Rear wheel release too long
C1158______Calibration required
C1206______Front wheel speed sensor frequency out of range
C1208______Rear wheel speed sensor frequency out of range
C1212______Front or rear brake not applied with decel
C1214______Rear brake switch always on
C1216______Rear brake switch open
for engine management:
P0131______Front Oxygen Sensor Low / front cylinder lean / signal shorted to ground
P0132______Front Oxygen Sensor High / front cylinder rich
P0134______Front Oxygen Sensor open / high / not responding
P0151______Rear Oxygen Sensor Low / rear cylinder lean / signal shorted to ground
P0152______Rear Oxygen Sensor High / rear cylinder rich
P0154______Rear Oxygen Sensor Inactive open / high / not responding
P1501______jiffy stand sensor low
P1502______jiffy stand sensor high
for instrument module
U1040______loss of ABS serial data at IM
