Tis the season to change your key fob battery.
If not, I hope you know the secret handshake to start it via the PIN.
Here are the PIN steps in case someone doesn't know
For anyone trying to set their 5 digit PIN in their F's security system here is how it is done:
Turn the ignition ON-OFF-ON-OFF-ON
Press the left turn signal switch 3 times
Press the right turn signal switch 1 time and release
The current PIN will display in the odometer
Enter the first digit (a) of the new PIN by pressing the left turn signal a times
Enter the second digit (b) of the new PIN by pressing the left turn signal b times
Enter the third digit (c) of the new PIN by pressing the left turn signal c times
Enter the fourth digit (d) of the new PIN by pressing the left turn signal d times
Enter the fifth digit (e) of the new PIN by pressing the left turn signal e times
To test the new PIN do the following:
Within 2 seconds of turning the ignition on press both the left and right turn signals at the same time and release
The odometer will display 5 dashed (-----)
Enter the fourth digit (d) of the new PIN by pressing the left turn signal a times
Press the start button and the bike will fire up
