Hi,
I have a 2013 NRS with idling-issues. I just can't seem to adjust it, and as it is now it stops after about 2 seconds after crank because idle-rpm is way too low. I have to pull the throttle to keep the bike running.
I've checked the ECM-map and numbers look fine in the idle-settings, so I have no idea why the bike isn't following those numbers.
I've tried "resetting" the IAC as mentioned in a couple of threads (ignition on/off 3 times, ignition on and wait 1 minute before crank) and no change.
The bike has Green high flow a/c, Akrapovic 2-1 full exhaust and mapped methodically with Power Vision. The bike runs flawlessly otherwise.
