Hi,
I replaced all pads, front and rear, after that hand lever loose hardness had before. Rear brake is very good. Someone told me to replace a brake fluid. I did it in front brake.
I bleeded system many times, no air bubbles, but also no any positive results. :banghead: Braking efficiency is very poor, when is beginning braking hand lever is very closes the grip. No leakage anywhere.
Any ideas where is the problem? Is it possible that brake pump, orings after 15k miles are broken down? How can I recognize that should I replace or fix the pump? (have HD any repair kit for brake pump, parts number - Vrod 2005)?
thanx a lot for any suggestion
Maciek
Maciek
