1 - 10 of 10 Posts
Departed the Fix.
Sort of considering selling my F since it really doesn't get used much anymore other than the occasional day ride. My GS works fine for my two-wheel fix as I find that I ride it a lot more (and a lot longer distances).
Looking for help on pricing-- Suggestions?
I'm NOT interested in parting it out-- too much time and effort went into it to make it the bike I wanted it to be, and to do everything at a level that was indistinguishable from stock.
Additionally, this is NOT a "For Sale" ad-- it's a request for information. If I sell the bike, I can sell my Kendon folding trailer as well, and thin out the herd of things with wheels that I own.
TIA--
R.
Here's the list of what's on the bike. It's mechanically perfect-- everything works, and other than a few small signs of wear, it's pretty much pristine:
2012 Harley-Davidson Vivid Black VRSCF Muscle
Mileage ~6000
Body & Trim
    • Airbox sound deadening pad: 3M (underside of outer airbox cover)
    • Belt guard: Tiger Racing 240, upper & lower (pc’d satin black)
    • Blind spot mirrors: K-Source, 2” convex
    • Clutch & brake foot controls: H-D VRSC (pc’d gloss black)
    • Coolant hose cover: H-D VRSC extended length (pc’d gloss black)
    • Document holder: H-D VRSC
    • Footpeg bolts: stainless steel w/ nyloc nuts
    • Footpegs (rider & passenger): gloss black RSD Moto, 45°
    • Fork badges: Bicep Designs, “VRSCF”
    • Front axle covers: Bicep Designs
    • Front fender extender: Pyramid
    • Front pulley cover: H-D VRSCR (pc’d gloss black)
    • Front amber side reflectors: removed
    • Gas cap: Stant 10501 (locking)
    • Hand grips: gloss black Avon Custom Contour
    • Handlebar riser: Budman (approx. 0.6” rise & 2.6” pullback) w/ aluminum wire cover
    • Headlamp mount: Altered State Design (pc’d satin black)
    • Headlight visor: Vivid Black H-D VRSCDX
    • Horn cover: gloss black Kuryakyn V-Shield
    • License plate backing plate: J&P Cycles (pc’d gloss black)
    • License plate frame: satin black Radiantz LED w/ H-D wiring connectors
    • License plate tail tidy: fabricated from H-D VRSCF international bracket & assembly
    • Luggage rack: H-D VRSCF
    • Oil dipstick: Trask
    • Passenger footpeg supports: H-D VRSCAW (pc’d gloss black)
    • Passenger footpeg supports (VRSCF): replaced w/ fabricated spacers (pc’d satin black)
    • Radiator intake armor: Bicep Designs
    • Rear axle covers: Bicep Designs
    • Rear (red) side reflectors: removed
    • Seat: Bitchin Seat Company, embossed leather custom Wifebeater w/ rider & pillion nitro-gel inserts
    • Seat hinge: BSC, fore-aft articulated (pc’d satin black)
    • Shift peg: gloss black Speed Dealer Customs
    • Swingarm pivot covers: Superchicken
    • Turn signal extension caps: H-D VRSC
    • Valve stem caps: black hexagonal aluminum w/ yellow radiation symbol inserts
Mechanical & Performance
    • Air filter: Amsoil high-flow nanofilter (EaAM43701)
    • Backing plate material (hydroscopic): Outerwears
    • Clutch & brake hand levers: Oberon Performance adjustable (black w/ silver inserts)
    • Clutch slave cylinder: Oberon Performance
    • ECM reprogrammer: TTS MasterTune
    • Exhaust baffles: TAB Performance, 1.75”
    • Exhaust header & pipe coating: Cerakote V-171 Ceramic Turbine Coat
    • Exhaust packing: Helix Racing, high-density
    • Exhaust pipes: TAB Performance, “no logo” slip-on
    • Exhaust shield & lower airbox heat barrier: DEI Reflect-a-Cool
    • Lower airbox: modified w/ H-D SE Stage II cutouts & IAT sensor relocation
    • Oil drain plug: Dimple magnetic
    • Oil: Amsoil 20W-50 synthetic
    • Oil filter: Amsoil nanofilter (EaOM136C)
    • Shift linkage: satin black Ghostrider Customs, hexagonal
    • Side grill backing plates: modified to allow unrestricted airflow
    • Spark plugs: H-D Gold (10R12AG)
    • Throttle sleeve insert: San Diego Customs, aluminum ¾ turn
    • Tuning: dyno tune & custom fuel map by Randy’s SpeedWrench of Denver, CO
    • Upper (inner) airbox cover: removed
Tires, Brakes & Suspension
    • Brake & clutch fluid: ATE Type 200
    • Brake pads: Lyndall Racing Gold-Plus (#7254)
    • Fork cartridges: Traxxion Dynamics Axxion AK-20
    • Front tire: Metzeler ME880 Marathon, 120/70/19
    • Rear tire: Metzeler ME880 Marathon XXL, 260/40/18
    • Shocks: Race Tech G3-S, custom dual-IFP w/ adjustable rebound dampening
Lighting & Electrical
    • Battery: Antigravity ATX12-20 lithium ion phosphate (660 cca LiFePO4)
    • Battery charger & maintainer: Optimate TM-471
    • Battery charging cable: Optimate SAE
    • Cell phone charging cable (waterproof): USB to SAE
    • Garage door opener: Mo-Door, 6"
      Gauges: Bluegauges.com, blue backlight w/ red needles
    • Hand grip warmers: Heat Demons internal 1” w/ black led control perch
    • Headlamp: Eagle Lights 5 ¾” Gen-III LED w/ halo & black reflector
    • Headlamp wiring harness: H-D H4 to H9/H11
    • Horn: Fiamm 130dB Freeway Blaster, low-tone trumpet
    • Security system: H-D Smart Siren II
Luggage & Touring
    • Bike Cover (indoor): H-D VRSCSE CVO
    • Cell phone mount: Mob Armor Claw Mount (Large)
    • Footpegs: gloss black RSD Moto, 45° w/ stock VRSCF brackets (used w/ saddlebags)
    • Lower windshield mounts: fabricated brackets & extensions (pc’d satin black)
    • Saddlebags: H-D VRSCF w/ “quick-installation/removal” modification
    • Storage pods (2): Timbuk2
    • Upper windshield mounts: Budman custom fabricated 3.25” post extenders
    • Windshield: H-D VRSCF Compact Mid-Sport
FBJ you're a wild man - I'm still trying to catch up with you on your R upgrade list - as always all the great things you did to the bike are great, but translate maybe into a 25 % return on your investment. Monday I tried to buy a crashed 2015 Muscle 6900 miles at Copart North here in Orlando - stock bike, both wheels cracked, forks broken, shocks, mufflers and fwd controls all damaged, rt. handlebar missing with brake reservoir, throttle, switch controls. Rt shroud, rear fender scratched all up, rt. radiator shroud smashed. Instrument cluster broken, throttle cables jammed in idle. No start No run. It got up to $ 4850 plus $ 1800 in Copart fees so $ 6650 plus approx. $ 4000 in repair parts plus approx $ 1500 in labor = $ 12,150 which is retail on that bike, without a salvage title -totally insane ! I just wanted the engine but using that logic your bike is clearly worth at least twice that, $ 24,300. Look at the advertisements for your year Muscle, average them out, add for low miles, add 25% of what you've invested in all those upgrades and there's your price - hopefully someone appreciates everything you've put into that bike, and pays you for it but what I see are idiots that fall in love with a crashed POS on the internet, and pay what they could have for a fine low mileage top notch bike like yours. Hopefully someone here realizes that and will come to the table for you but lots of folks are out of work now so its a tough time to sell - you might want to hang in there with it for a while till the market comes back - Good Luck ! (y):D
Hate to see someone else selling .....
Generally here in the U.S., the bottom has dropped out of the V market. All those extras? You may as well give them away, as they wont add one nickel to resale value. I find these facts sad, but its reality. Like another said, hold on if you can. I think someday the values will return to what they should be. Now, if you were in Europe, (maybe you can find room in a cargo hold for it, next international flight) that bike would easily fetch 20k.......
Yes, I agree. But place to sell is here in Australia. I bought my VRSCAW with 9000 K's for AUD16900, a plum price. It's now done 21000 K's and I would almost certainly get what I paid. Just added heated grips (something essential in Melbourne), new Pirelli's and brake pads. Already had a few additional bits, but nothing like the fly boy's masterpiece. Sold my Road King and now own this rocket. Best bike I've ever owned and I've had a few.
Used to do the turbo but changed to supercharged. 696hp 620 trq at the wheels. They are fun.
back to your bike. I see prices all over the place. Most mods have very little roi. I see higher prices on FB and eBay than forums where people know the true value. Good luck with whatever you decide.
TIA--
R.
Mileage ~6000
Body & Trim
totally wow, do you have pics of the beast ?
Departed the Fix.
Discussion Starter #10
If you look for "The Modifications Begin" in this subsection, you'll find an entire thread with pictures.
At the moment, the bike is stored over at a buddy's house and he's gone on vacation for another two weeks.
1 - 10 of 10 Posts
