I know when paint tanks or what ever prep is the key part that makes or kills the project.
I got the paint, gun, and everything I need to shoot my tank on my suzuki and have a question.
When I drain and remove the tank should I flush it out with something like say soapy water then rinse and add some rubbing alchole to remove any left over water before spraying, or just drain it and turn it up side down and let it sit for some time?
Is removing every bit of gas and fumes needed for paint the outside?
MODOHOLIC ANONYMOUS
I just drain them and let them sit for a few days... Never had a issue
I am going to get some aircraft stripper or I think thats what it is called and strip it tuesday. I am going to pull the tank and drain it monday.
Should I strip it then clean with say rubbing alcohol to insure it is clean?
