I was wondering if anyone knows if I can purchase a shorter power cable for the powervision? Or is there a way to shorten the cable? Thanks again for your guy’s help.
Not sure the coiling actually was ever the issue. Some units had issues and the cable was blamed, rather then the PV unit itself. Don't remember what my cable is exactly but in the area of 18" or so from the data port to the hard mounted PV unit. You need to do a test fit and decide what's best. For a none hard mount, leave it as is and wind up the excess while in use.Thanks Ron. I really appreciate the help. How long did you cut the cable, I’ve read that coiling the cable causes problems. Also should I dyno my bike or is using the basic auto tune ok to use?
