My battery is dead and im gonna replace it with new battery . if i remove the old battrey, is the map will reset from my power commander or not ??
Where's Max?
Are you referring to the 9-volt battery? If so, your map should be fine. The 9-volt is just to supply power to the PC3 so you can load the map on it, instead of having to turn on the bike.
Justpassinthru
Are you saying there is a 9 volt battery in pc-3 tuner ? I never checked that one, but unhooked and rehooked up main battery a few times and no promblem.Had tuner on it for over 5 years .
