21 - 34 of 34 Posts
VRSCF
Dyno Plot 2012 VRSCF Stage 1 Harley generic map
Year: 2012
Model: VRSCF
Intake: K & N
Exhaust: Vance & Hines Competition Slip-ons
Cams: standard
Other: standard
A few base runs with the generic stage 1 map as supplied by Harley with a Super Tuner
113.9/76.9
VRSCF
Dyno Plot 2012 VRSCF Stage 1 custom map
Year: 2012
Model: VRSCF
Intake: K & N
Cams: standard
Other: standard
Revised stage 1 map, a few tweaks for improved AFR. Programmed via HD Super Tuner.
117.4/78.7
'04 1300
Year: 2004
VRSCA
1250 bore
Destroyer Crank
1MM oversized valves w/ Jones springs
Jones 480/455 cams
Destroyer TB
Destroyer injectors
VRFI-III
Boss NOSS dry kit w/ fueler
2x25 HP nozzles
The engine was built in 2008, has about 21k miles on the build
Autobanmod
Year: 2004
VRSCA
1250 bore
Destroyer Crank
Jones 480/455 cams
Destroyer TB
Destroyer injectors
VRFI-III
2x25 HP nozzles
Looks very nice.
How much boost?
And what changed between run#1 and #2?
'04 1300
Looks very nice.
How much boost?
Thanks! Not bad for an old bike.
No boost--BB (1300cc) plus a 50HP shot of nitrous, which looks to be over-achieving, as on an average dyno, this build's put down 138HP NA for the past 10 years.
Run 2 was actually run 3 (the dyno didn't record run 2 for some reason), and, since I don't have a purge solenoid (yet), I think run 1 didn't get a full shot. Other than that, no changes at all. Both bottles were full when they were opened for run 1.
True Track Stabilizer
SE 58mm THROTTLE BODY ASSEMBLY
Trask +1 qt. Deep Billet Oil Pan
Trask-V-rod-billet-clutch-basket
Trask-V-rod-crank-girdle
Trask-V-outboard-bearing-support
Trask-V-rod-billet-dipstick
Trask-V-rod-turbo-system
Thundermax-fuel-injection-module-
w/auto-tune.
'04 1300
Year: 2004
VRSCA
1250 bore
Destroyer Crank
Jones 480/455 cams
Destroyer TB
Destroyer injectors
VRFI-III
2x25 HP nozzles
NEW:
Walbro 255 fuel pump
5 bar fuel pressure regulator (and corresponding tuning adjustments)
186.78 HP - down a bit, but AFR's are in much safer ranges. I'm getting way way too much fuel in the rear cylinder on the nitrous, but that creates a nice opportunity to refine the tune and find some more HP.
Here's a video of the dyno run:
'04 1300
Continuing to push it:
Year: 2004
VRSCA
1250 bore
Destroyer Crank
Jones 480/455 cams
Destroyer TB
Destroyer injectors
VRFI-III
2x30 HP nozzles
Fitzgerald Motorsports crank brace
Fitzgerald Motorsports billet oil pan
Fitzgerald Motorsports clutch basket
New HD slipper with Barnett springs
The first 3 runs were just motor, then sprayed on the last 2. The fuel pump/regulator work I did last year got me about 1.5HP on motor too--this motor's never broken 140HP until now.
604792
Damn that's stout sburke91! IMHO if that engines stayed together why go Turbo or S/C'er ? I'm not a big NOS fan but here when managed correctly it's a hit outta the park - and without NOS the engine is awesome on it's own so why lug around a big ugly weighty Turbo or S/C setup ? just get the power when you really need it, enjoy N/A flexibility and simplicity the rest of the time - Win Win. (y);)
Year: 2014
Model: VRSCDX
Intake: K & N Filter
Exhaust: Akrapovic 2 into 1 Open Line
Cams: stock
Other: Power Vision with Target Tune
Learned afterwards these bikes have a cold rev limiter until they're warmed up. So for now this is what I have up to 8k rpm:
604808
'04 1300
That was my original plan when I built the motor in 2008/2009--streetable power everyday, but with enough strength to take a 'small' shot of nitrous. I think I've gone a bit beyond the 'small' concept, but it's a great Jekyl/Hyde combination now, although a bit sad when the bottles go dry :D
21 - 34 of 34 Posts
