I had an oil leak, which I had originally thought was from one of my breather hoses (when putting the airbox back on, I didn’t get the rear breather hose on tight and I did spew oil.) Upon closer inspection I found this. Is this normal? Is this where my constant oil leak is coming from? Ever since fixing my fuel issue, I haven’t experienced any issue with performance, only thing is the slight oil leak and overall heat. If an issue, is it fixable? Can I add some type of rubberized adhesive or a type of weld to keep integrity? Or is this just some type of gasket/bond that came off and it’s nothing to worry about. I did pressure wash my bike this week, only the engine area, and on the medium PSI setting. Idk if that could have caused it, but probably most likely. Pictures attached
