1 - 13 of 13 Posts
A quick inspection prior to riding tonight and I found that my back tire seems to be coming apart! Does anyone know what would have caused this? I always check tire pressure and this tire has about 6K miles on it (no burn-outs on this tire). The tread depth is fine. I guess I won't be riding tomorrow. Has anyone else had this problem with the 180 Dunlops?
Dilligaf
Dude, The wear indicators are showing on that tire meaning it should have been replaced.
Part-time mod
Yup, time to replace it!
Thanks. Yeah, I'll probably go with the Metz 200, this time around.
Jared
looks the SAME as mine on my R right now, i got 5300 out of it, couple rolling burnouts, thats normal wear it looks like to me...what psi are you running?
Friend of Max.
Mine look like that ALOT. :hidesbeh:
Yes, the tire is worn out as is obvious and others have said.. but it also looks like at some point it was bottomed out and hit a screw up under your fender.. That's where the center grove is probably coming from. It will probably happen again on a new tire too unless you fix the problem when the bike bottoms.. Maybe you lowered your bike?
1 - 13 of 13 Posts
