1 - 9 of 9 Posts
I have a Pingel Electric shifter installed except fo the shifter button. I have the wrong button setup for my bars. Has anyone wired the shifter into the L and R turn signal buttons?
Not that I know of...but I don't know why it wouldn't work......provided, of course, that you didn't plan on having turn signals......
The Hawk
If you have the 7/8" switch you can bore or drill it out to 1" and it will fit. That's what I did on mine.
Mike
OK everything is wired in except the up and down controls. I really want to try this out. Can someone point me in the right direction on using the turn signal buttons?
The Hawk
I run that little mini 2 button switch that Pingel sells, came with my kit.
Mike
the Dale Walker kit requires that you actually lift the shift lever with your foot.....this tugs on a spring switch that kills the ignition during the foot shift process.....not a pushbutton shift like the electric or electric over air.....
1 - 9 of 9 Posts
