I bought a Pingel Kill Teather and need to know which wire on the run/ off switch to tap into. I have a 2007 VRSCX. I think it might be the Yellow and Black wire. Is this correct? Any additional information would be great.
Noel
Either if you're tapping at or near the handle bar switch, the pingle will be in series with the stock RUN/STOP switch.
I wired mine in under the instrument cluster (on an A model) where the wire bundle can be cut open
The Hawk
I wired mine into the handle bar on/off switch wiring and used the grey wire, works great.
Mike
I was planning to splice the wires in under the left side louver cover before the first junction connection. As long as I tap in before the junction it should be fine, right?
