Just watched the TTS V Rod install video - amazing product, if not a Turbo Mike 882 should consider this TTS S/C setup totally professional kit amazing machining and 6-8 psi 165 Hp or remove inlet restrictor and 10-12 psi 200+ Hp. Plus no crazy exhaust pipe plumbing and not quite as ugly as the rt. side turbo kits. Ultimate Hp not as much as a big turbo and full frontal intercooler setup but S/C may be easier to install and live with on a stock engine. Don't like no intercooler but not sure what IAT is compared to a turbo. One consideration is mid peg bikes are not the place for the TTS, left knee will hit the S/C - seems the rider swings leg up underneath it for fwd. controls which really is the best setup but then you're drag racing a fwd. control cruiser type layout, which seems a bit odd and counterproductive. Might be better to have mid pegs and rt side turbo for drag racing, since its farther forward and will clear the rt. knee - and be easier to launch than fwd. controls. I'd like to know how the S/C kit vs Turbo kit in standard form compete against one another in the 1/8 & 1/4 mile - I'm thinking S/C may get out of the hole better, turbo may do better on the top end -
