Been busy with a few other projects, (e.g.
https://www.ninjette.org/forums/showthread.php?t=174473 ) but I'm still around.
I no longer sell the full kit. I only sell the software. However it's pretty easy to configure a kit DIY style.
You'll need an Android device, the Portable Dashboard app, a bluetooth enabled scantool, and a pigtail that connects the scantool to your bike's data link port. You'll be able to put the entire system together for < $50. (not including the Android device)
You can download Portable Dashboard from here...
https://play.google.com/store/apps/details?id=com.portabledashboard.pdash
You will need a OBD2 compliant, bluetooth enabled, scantool to communicate with your motorcycle's ECM.
I use this one... (Last time I checked it was only $11.65!)
http://dx.com/p/elm327-bluetooth-obd-ii-wireless-transceiver-dongle-16921
But there are many others.
You will also need to make a cable to connect the scantool to the motorcycles DataLink connector.
Here is the How-to...
http://users.eastlink.ca/~reastwood/MobileDisplay/HowTo.html#Assembling the Datalink Cable
Once you have these components, you can try it out on your bike. The application is fully functional.
The only difference between the demo and the licensed version is that after 10 minutes the demo version's display will stop updating. You can restart the app and you will get another 10 minutes.
If everything works and you are happy with it, you can purchase a license for $30. In this way you can fully "try before you buy".
Thanks for your continued interest.
-Bob
