Chad 02 V-ROD
I installed the pc last week with the 020 map for v-mod, SEfilter. I'm running with the top on now the bike dies when I stop and seems like it is running hotter to. I did put water in the cooling system when the hose was leaking so I'm going to drain the system and refill with the HD dexcool.
thanks for any input.
Chad 02 V-ROD
VrodG said:
You can run without the top with the -20 map
OK I'll try it and see if it helps
MASTER VR TECH
IMHO Get your money back and look to an E.F.I Race Tuner. Your best bet. And also, WATER BAAAADD. Later SKI.
