hey guys, im currently running stage 2 cams, k+n filter, v+h indy pipe and the pcIII backing it all up. just wondering if there is better performance to be gained from any other kind of tuner? any feedback would be good..
It is what it is
What map are you using I am looking for a map for my current setup? Also look into the VRFID from OHIOvrod that is my next purchase.
If you had it dyno tuned you're probably getting everything out of it you can. I've never seen anything to indicate that any particular tuner produces more horsepower.
Discussion Starter #4
it has been dynod, i had standard headers with tab slip ons first and it spun up 2.? more hp than it did when i put the v+h indy comp pipe on.. indy pipe makes it alot fatter through the midrange though!
