1 - 2 of 2 Posts
THE DORK-ROD
Just got the usb model, anyone know what the adjustment range is on this thing? I see a wide range of #'s in the maps posted, 0 must be no change is 25 a 25% increase? What about a -85 # ? Yikes That sounds pretty lean.
Dilligaf
yes 25 is a 25% increase over stock and the negative numbers will mostly be in the zero throttle range but yes they are negative % under stock.
1 - 2 of 2 Posts
