Installed V-mod pipes (I did the work), plus a K&N Filter and a PCIII mapped for me by V-Mod. I am running TOP-ON and have a slight hesitation in the low range. I downloaded and installed the mjw map but the notes in it says for Screaming Eagle filter. This map supposedly is a version created for VALs bike which features a K&N filter.
Which is it or does it make any difference or are the notes just incorrect?
I have not checked out middle and high end range yet.
The files, as stored on 1130cc.com, have a file type of .map. I assume I just change it to .djw or whatever PCIII expects and they will work. Is this correct or did I just screw up things?
Also this hesitation I am experiencing. Does this mean it's running lean or rich? RPMs about 3000 is where it is most noticeable. Smooths out after that. Most of the posts here deal with middle to high ranges so I am at a loss as to where to proceed. I have installed the mentioned mjw map and will try it tomorrow. It's raining right now and will be wet roads for some time.
