· Friend of Max.
Try the one from my GF's 2006 Night Rod. Link Here. It may be a bit rich with the stock air filter, but Rich is better than lean. RJ
· Registered
pirateparrot said:
Anyone have a MAP for stock air filter with stock exhaust baffles removed?
how easy was it to take out the stock baffles? because my dealer says that there is nothing in there that I can work with.
It looks to me that if I undo those three screws, I'm half way there.
But if you've already done it, then your the man that knows.
Rob.:notworth:
· Dark Knight
Rob.:notworth:
Here's the quick breakdown for ya.
1. Remove the endcaps
2. Using a 3.5 inch hole saw, cut through the end of the can around the endcap bracket.
3. Pull the baffle out of the can. May require quite a tug.
4. Repeat 1-3 on second can.
5. Take the bike for a short ride and rev the engine to blow any excess metal shavings out of the pipe.
6. Using a small metal screw, reattach the endcap. Run the screw through the side of the endcap into the can.
Enjoy the new sound.
· Registered
07 maps have adjustments in smaller increments for RPMS....06 went 0, 500, 1000, 1500 RPMS...etc 07's go 0, 250, 500, 750, 1000........
That is the most noticeable difference there may be more, I don't know. People who have contacted Powercommander where specifically told not to load an 06 map on a 07.
· Registered
Dream I have ran your map for about 20 or so miles and it seems to run good. I dont get the decell popping you talked about in the other thread. I'm making a trip to the drag races in norwalk tomorrow and will be back on sunday so hopefully it will work out good. I'll let everyone know how it goes.
