1 - 13 of 13 Posts
I have a 2007 VRSCX Vmodded pipes PCIII USB and K&N. Bike was dynoed and AFR look good (Straight line most of the way) but I have real loud decel popping.
Can anything be done about this? Bike runs great otherwise.
Jr. Lifetime Premium
I have learned to live with it with the CFR. When I had v-modded pipes, it was not that bad. What is your fuel setting at zero throttle 5k RPM and below?
1130cc Ninja
cfr's here and they do it too.. i was always told to add some fuel at 0% throttle at the rpm in which it seems to pop.. does this hold true to real life?
I was just looking at the current map and the 0 Throttle settings appear to be all screwed up. Attached is a print of that map.
The map loaded when I had it dynoed was obtained from this forum and was titled "Dawgs Custom map Dyno Tuned.djm".
I am going to alter those 0 throttle figures to be the same as the map supplied with the PCIII as shipped from V-MOD. There was no popping on VMODS map but it did have a flat spot at 3-4K rpms.
Edit: It's going to be a couple of weeks before I can do this. I'm going to KC for the rally then to Texas afterwards for a few days.
Never had a popping problem on decel with the CFR -- until lately. Started doing it a month or so ago, and had me concerned about what may have changed? Cleaning up the bike a week ago, I noticed some soot on the pipe just after the figure-8 clamp indicating there was a slight exhaust leak...
Retightened the clamp and no popping anymore! I was able to get a half-turn or so into the clamp. Guess it's another one of those things to check on every once in a while.
1130cc Ninja
the cfr's are bad about getting exhaust leaks.. mine does it too
I tighten mine every 2 weeks at least
This is a reply to my own post. I altered the Zero throttle settings on the map I posted and most of the popping went away. Set everything in the zero throttle range to 0 except the 1000-3000 range which I set to 10's and 5. A little popping is left but very subtle and sounds good.
Discussion Starter · #11 ·
Spaz said:
Try this one and see how it works for ya.
Spaz,
Thanks. I tried your modifications and things sound much better. I had just a little popping at 2.5K and a whole bunch at 4K. Some minor adjustments to the map and I am good to go. Being a newbie on PCIIIs I was a little hesitant in doing this myself but your input gave me the courage to make changes.
Dilligaf
Glad it worked out for ya, by looking at your adjustments you got the idea!
141hp/91 Ft lbs tq!!
I get a "pop" (just one) when I'm cruising at around 70 mph/35-4k rpm right when I twist the throttle and accelerate on up to 140 mph and points northward. I always thought it had to do with my PCIII settings but ain't complaining about it. Thought it was kind of cool the way it worked and PRESTO! I was gone with everyone disappearing in my rear view mirrors.
Now I'm going to go check all my clamps/fasteners on the exhaust.............
:hmm:
1 - 13 of 13 Posts
