1 - 2 of 2 Posts
SMOKE A FATTY!!!!!!!
well I can't seem to get much help from the EFI room, so ill ask everyone. I'm running topless, KN, and header pipes only (see gallery). the map that I have is for the KN and stock pipes with the baffles removed. I turned the fuel up 2 settings to keep from running to lean. it seems to be running fine (im no mechanic) just a little poping around 5 to 6k. hope you can help.
Dilligaf
You might want to try a map for the v-lux pipes if there is anyone here running them.
1 - 2 of 2 Posts
