It seems I've joined the long list of owners with a failed output shaft bearing.
More than competent at doing the job myself, but from the experience of others I have a couple of questions:
What fasteners are best to loosen while the engine is in the frame?
And does the clutch need to come off?
It looks like I need to make alignment pins for the alternator cover, and a retainer for the gearbox shafts, but other than that, any other special tools I need to make?
I was going to replace both bearings on the output shaft, and the mains while the motor is open.
Any other hints and tips welcome!
Phil
Phil
