Is there an online V-Rod parts microfishe I can go to. I've got chrome peeling off what I believe is the outer rocker cover. I just want to confirm I've got the correct name for the part. Then I need a reference number for the part also. TIA :helpme:
just to get straight... the v-rod doesnt have rocker arms, so therefore no rocker covers. i suspect you are talking about the cam cover.... there are 2 pieces on each head.
the main, lower cover [front: 17661-01K] and [rear: 17667-01K] are the ones sitting directly on top of the head.
the smaller upper cover [17664-01K] is the same front and rear.
you will also need gaskets [17416-01K & 17418-01K] as individual pieces... or [17010-01K] as a kit, which gives you 2 of each.
hope that helps...
