http://www.1130cc.com/forums/showthread.php?t=68876
Thanks RJ for letting me know what the two wires were! RECAP: the Blue & the Vivid Yellow wires need to be spliced together.
Found a much easier way to do it than screwing with the 6-pin connector behind the left cover.
Tools needed:
Electrical Tape - Gardner Bender Tap Splices 22-18 AWG, item #21-2218 (red) - Plyers - Small Sizzers - Metric Hex set
Modification:
Disassemble the lefthand switch cover.
Use the sizzors to slice a small length of the black shrink tubing from the wire set.
Locate the Blue & Vivid Yellow wires. Tap Splice those wires using the plyers to make sure the splice takes hold.
Wrap the set back up with the electrical tape.
WARNING: DON'T LOOK DIRECTLY INTO THE HEADLIGHT OR YOU WILL GO BLIND!!!
Tools needed:
Modification:
