Welcome
Try a 7000 rpm launch then short shift second into third as quick as possible to see if you can get past the limiter issue1st pass: easy launch at 5500, went straight, got off of it at 900 ft. ran 10.0 to there. Bounced off the rpm limiter pretty bad. Wasn't ready for it!
2nd pass: launched at 6500, hit the launch rpm limit at 7160 and short shifted it. Wouldn't go higher. got off of it early.
3rd pass: tried completely filling the gas tank on the off chance that it was fuel starved. launched at the limiter 7160 wouldn't rpm higher.
4th pass: Checked, probed and prodded everything that I could think of before I ran it. Same results.
At least got some seat time! Had fun. Will check limiter and clutch switch functions. Last owner had a Pingel shift button on it, it doesn't work well with my hand so I went back to the stock shift button. It shifts correctly with the stock button, but I wonder if there is an issue with it or the clutch switch(it has been replaced, I can see the spliced wires). I can check the rpm module with my ignition driver too. That's on the list. TIMINATOR
