Got a 2008 HD vrscd night rod 1250cc oil is leaking out of waterpump weephole on inner block piece there's a shaft with 2 o rings on it metal gaskets can't seem to figure out why it blows oil
If it is only leaking out of the weephole and not getting into the water then you need to check the O rings Part no. 11366K on the bearing hsg and the bore they fit into.
I've replaced them many times the orings there so thin and not much clearance to put other ones in 3rd time or so I've done it
its usually the waterpump gaskets that fail.clean the sealer off the gaskets and reseal with gasket sealer such as used on crankcases.
Discussion Starter #5
I'm not leaking antifreeze at all there is only so much clearance on the shaft where o rings sit 2 of them feel like its coming past them but they are not bad
