Hello All
I have a 2009 V rod Muscle Seem to have developed a little oil leak . Left side top of the engine right by the Front valve cover bolt I did try snugging it but it was on tight Any of you had this issue
Thank you
Chuck
Oil breather o-ring on the front cylinder. Search for it on the forum, super common issue. Easy to fix (also possibly cracked breather hose on rear cylinder breather.
I have an 09 Muscle and was one of the first things I fixed when I bought it used.
Get a service manual if you aren't comfortable.
Discussion Starter #4
Greeting all
You were correct Broken O ring on the front breather Thank you all for your input
However after running the bike with the engine off leaning to the left on the kick stand it leaks a little oil from the top 2 bolts of the primary cover ( this being the cover with 1250 stamped in it ) Have any of you seen this before
Thank you again
Chuck
