Got my 10K service done at the weekend, except valve lash as I decided to go with majority advice and wait until 20K.
I would recommend the DIY route to even the least technical of us because you will almost certainly take more care than the average dealer tech. I had ordered a new throttle body gasket as I knew the existing one was damaged (dealer or original fit I dont know). Its amazing what you discover when you follow someone elses work on your bike, the gasket was well and truly chewed up and lots of oil on the top of the rear cylinder. This might explain the weeping oil I was experiencing around the top of the rear head?
However when I came to pull the rear cylinder sparkplug I discovered that it was sitting in about 5mm oil
Question could this simply be a build up from the air cleaner blow by due to the gasket or is it getting there from somewhere else? I could not see any evidence of apparent leak but as anyone knows who has done the job them plugs are in deep!
I cleaned everything up, completed the plug change and reassembly and oil change (Syn 3).
Test rode seemed OK with the bike pulling cleanly and my imagination or not a little quieter top end.
Yesterday on the open rode found a quiet stretch and took it to the reline through first four gears and leveled out at 115 in top and held it there for a couple of miles, nice:angeldev:
I fitted the NGK Iridium plugs and pick up and general pull seemed a little sharper but that could be the overall result of the service.
Question to the techs out there, have you seen this type of oil 'leak' before and should I be worried and get it investigated? For the moment I am monitoring.
All opinions and advice greatly appreciated.
Regards
Skin
Regards
Skin
