Sam V said:
I don't recall accusing anybody of building a "defective" engine. ......no damn way that an engine should take such a long time for rings to seal unless there is some problem with the geometry of the rings and liners......The fuel dilution issue is not a freak incident, but seems to be common to many of you.
Sorry: But that sounds pretty much like an accusation of a defective engine to me.
As I am sure you are aware, virtually every major automaker (GM, Ford, Toyota, VW) has at least one ongoing complaint against it, claiming "excessive oil consumption" - do a Google search on those keywords and see what pops up. I'm not saying that there isn't a problem there - but I tend to question how this sort of scenario came about. Are engines today somehow vastly inferior to those of prior decades? Of course not - but I believe that two things have combined to make this sort of "problem" more apparent: 1) Piston ring placement much closer to top of the piston and 2) the virtual disappearance of "full service" gas stations - where a helpful pump jockey would check (and fill) your oil at every fill-up. Now the only time most people get their oil checked is every 5000 (or 7500, or more..) miles when they take it in for service.
In the case of the V-Rod I believe we have created a self-fulfilling prophecy. Somebody claimed that the oil "smelled like gas." I remember the first person who had this experience and sent an oil sample in - and discovered that the fuel level was fine - but that for some reason the zinc level (or some such mineral) was slightly high. Now we have a case where another owner has oil analyses that DO show an elevated fuel level. But are there any other symptoms, or problems? Not that I can tell - but you can be absolutely certain that if ever anything ever goes wrong with his engine that oil analysis will "prove" that defective design or assembly was at fault.
There was an episode of "King of the Hill" a few weeks ago, where Hank made the mistake of allowing an "expert" to test his walls for "mold." Of course, tests proved that there was mold, and as a result he got his house torn apart - to correct a "problem" that wasn't doing any harm to anybody. The point is, if you look hard enough, and do enough tests on it, I'm sure you can find a fault with pretty much anything.
I don't think that we are doing ourselves, or anybody else, a favor by creating an environment of unreasonable fear, where people are sniffing their oil, and mailing samples of it across the country. I'll keep changing my oil on schedule, and worry about defective engines when a whole bunch of V-Rod's start breaking down.
