1 - 9 of 9 Posts
Greetings all,
I am doing my first oil change on the 2009 VRSCAW. I presumed that under the oil drain plug would be some kind of gasket or crush washer. I checked the drain pan, on the plug and on the floor.... no gasket or washer to be found.
I then looked in the parts book that I have and no gasket or washer.... :deal: that book has been wrong before though.
Is this correct, that the oil drain plug does NOT use a gasket ??
Thanks
VROD JUNKIE
Use your torque wrench. There are plenty of stripped oil pans reported here.
Do not over tighten........
I am getting to the point where I am scared about my next oil change as last time I did it the thread wasn't feeling the best.
And a new oil pan isn't a cheap replacement.
durata membro
You don't need a new oil pan if it gets stripped.You can install a steel thread sert that makes it better than new.Don't use a helicoil,a solid thread sert is what should be used here.
It has to be tight or it will drip...
I just picked up some nylon oil drain plug washers at the auto parts store and used one. Doing so means I don't have to make it so tight and don't have to worry about stripping it.
timesert.com is the web site. Question is..... what size is the drain plug for the vrod?
The thread for the oil pan drain plug is 14 X 1.5 mm but I’m not sure how deep the threads are.
Here’s the website for Timesert metric kits.
The standard kit has 17.5 mm long inserts (part #1415) but you can also get #1415C with 9.4 mm inserts or 1415A with 12.7 mm inserts.
1 - 9 of 9 Posts
