1 - 18 of 18 Posts
Hey just wanting some advice please just put new crank in my 2015 muscle
on startup it blew oil filter seal out and oil everywhere thought it was airlock but no
I put Lucas stabiliser on all bearings and 20/50 in motor oil is now quite thick blew oil filter seal again after bleed so do I look at oil bypass? Just thought I’d ask before removal cheers
Autobanmod
The original oil filter type has an internal bypass valve. Also the oil pump has a safety valve which opens at about 6 bar.
Did you modify this?
I had a new filter sitting from a 1130 I used which has valve in it I think it’s my problem ?
All stock v rod filters have a bypass valve in the filter. You want that. The pump also has a relief valve that pops open at a set pressure. I doubt the stabilizer was the issue here although enough of it can block small passages and raise psi a bit above normal on a cold start with thicker oil. It should not blow the seal out though. How snug did you turn the filter on and which model pump do you have as in early or late?
2015 muscle tts supercharger ,2nd time done it up tight with filter tool ,motor has just been pullled down for new crank could I have done smthn wrong?
Normally it's a 3/4 turn more after contact on filter at most. I can't explain why it's doing what it's doing. Only thing I can think up is if it's cold while you are doing this, try heating up the oil pan first with a heat lamp. This might help move the oil along until it moves all that Stabilizer out of the way. Let's face it a filter is pretty fool proof and if it's the same oil pump with no relief valve mods done to it, cold oil and up stream blockage is the only thing that makes sense. Heat lamp the sump and engine bottom and try one more time.
The Hawk
There is an oil flow path diagram in the repair manual. The oil comes out of the oil filter and goes directly to the oil cooler. Check to make sure the oil cooler is not blocked. Pull the oil cooler lines out of the block and try to blow compressed air through it. Look for kinks in the cooler lines. If that is ok then try blowing through the cooler line fitting on the block. The bearing shells only go in one way with the notch into the groove so it would be very hard to get that wrong.
Sent from my iPad using Tapatalk
Discussion Starter · #12 ·
I have the old pump out of the 1130 it looks better than the 1 in it is this what you ment by which pump ?
Discussion Starter · #13 ·
Yes done all that my oil pressure is reading so that explains no blockages , will post after I’ve done releive valve as it’s my main suspect
What oil pressure is it reading at the oil sensor location. That might point to if it's the pumps relief valve. Normal for late model pumps is in the 60-70 psi cold start. No experience with pressure readings with the 1130 pumps but likely in the 80-90psi cold start.
Oil filter would be the weak point of an over-pressure situation.
Discussion Starter · #15 ·
I’m just going off the light going out ,I pulled apart and the relief valve is at the pin end is that open or shut?
Valve is under spring pressure, so closed until it's set spring pressure allows it to open. If the valve is stuck at the bottom this can explain it not bleeding the pressure off and the surge blowing the seal out. In a reverse situtation, if the valve hangs open, idle pressure will be very low. As far as I know the only adjustment is shimming the spring or a different spring rate. Neither of these should need to be done but make sure the valve is free to float and not stick.
Discussion Starter · #17 ·
Was the relief valve on pump put 1130 pump on and algood
Next issue bike fires for 5sec then dies have to cross solenoid button not working ,
My mechanic lost key previous and it’s had no fob but after sitting with no engine .....
I hvnt had time to read forum for awnsers
Discussion Starter · #18 ·
Fixed was a earth wire on rocker cover had broken off
1 - 18 of 18 Posts
