1 - 16 of 16 Posts
What does adding an oil additive such as Lucas or others do to the wet-clutch on a bike?
Is there anything to be concerned with?
If/should any be added and if so what brand works well?
Thanks
Just say NO to additives!!!!
If the "additives" were needed they would be blended into the oils in the first place. They should not be used in any engine.
AIM Bagger Edition
:them:
If you need an additive, you aren't using the proper oil.
Pat (Patrick!)
1 shot of Canola oil, per quart of Amsoil, will add 5 hp.!:hidesbeh:
(And it smells great, too!:D)
Pat (Patrick!)
....maybe if you're cooking french fries. :chair:
We now use the term "freedom fries, to be politically correct!:D
drag racer
durata membro
:them:
If you search around the internet for the different oil applications,you will learn what the mixtures are,what applications they should be used in and why a specific oil is used.
2 key words to use are zinc and phosphorus.
1 - 16 of 16 Posts
