:them:
installing O2 sensors on your bike in its current configuration will have zero benefit for you. If you decide to install a tuner/fueler that uses the O2 sensors, then that's a different story.
:them:
Narrow band switching type sensors are all the factory ECU is going to see anyway.
Replacement ECU's (TMax - YECH!, TwinTec) with autotune add-ons will see wideband O2's. Piggybacks (PCV's, etc.) will see them with their add-on autotune modules also.
A majority of aftermarket ECU's/Piggybacks use the Bosch sensors, which are great - but beware - if your bike came with bungs installed (factory pipes), you're going to have to bend the rear pipes bung rearward, to keep the sensor from jamming into the block. GET IT DONE when you go to install your sensor - so you only have to pull the pipe once. Front one R&R's on the bike, back one you pretty much have to pull the pipe to get the longer sensor in.
Before - OUCH!
After - Ahhhhhh...
Regards,
Rick
