Great explanation Ron & mukle ! I'm thinking in the newer ECU's H-D used narrow bands due to more reliable and more of an EPA pollution control devise to target AFR a bit lean than the wide bands that work in a greater range of Rpm for tuning to whatever AFR you choose, at different Rpm's, but they may be less reliable long term.
At least for my early non NB feedback ECU it seems best to use the PCV & WB AT to get the tune right at my most often ridden in temp then lock it in and remove O2 sensors. I understand high overlap cams can mess up the standard OEM fueling so using PCV WB & going back to open loop after a proper WB auto tune is complete seems to make sense. DTT suggested to me to go open loop in cam overlap affected areas and closed loop in other ranges and run WB's at all times, from what I remember when I looked into this a few years ago. Ron +-2 up to +- 5 % seems to be a pretty damn accurate tune on a boosted bike, and still with OEM ION Sensing seems to be as good as it gets - not always an easy path for the average guy though, but then DTT install, setup and tune can be a bit daunting at first use as well I'm sure. Thanks Guys, great conversation - hope others that don't know all these details read it !
