1 - 2 of 2 Posts
2008 Night Rod Special. Not starting. Checked and had pulse to fuel injectors. Changed fuel pump and fuel filter. Started right up and let it run. Turned off. Fixed oil leak at oil cooler. Started up and ran to check for leaks. Ran good. Shut down and put everything together “Plastics”. Ready to leave and no start. Had fuel pressure to rail 60psi chef for pulse to injectors. No pulse. Checked fuses and relays. Not sure what to church now. Please help!!!
Check for 12v to injectors. The ground is done through the ecm to trigger each injector. 12V comes for the system relay but also powers the fuel pump and coils. Not sure but check ECM fuse.
1 - 2 of 2 Posts
