Got an '08 VRSCAW with newly custom painted tins and a silver frame, so I wanted to change out the stock black brake and clutch master cylinders for silver ones. Take off the old, mount the new, re-attach the lines and gravity bleed to clear any air. The front brakes are fine, but my clutch is gone! Absolutely no pressure or resistance on applying the clutch lever. I can open up the bleed at the clutch and fluid flows when under gravity and flows faster when the handle is depressed. Close it all up and grab the clutch..nothing! Help! It's got me going crazy!:wazzup:
