911Punisher
The brake switch behind the brake pedal is going (has gone) bad. Mine went "bad" before 20k and had it fixed at the dealer under ESP.
:them: mine failed last October
Riding the good life
And it could be leaking internally too, where brake fluid is getting onto the switch. A freind had that happen, lost lla ht efluid, no rear brake on a ride from Kitty hawk to Cleveland and road part of th edistanc ein heavy rain without the rear brake.
When you change the switch, check to fluid to be sure none was lost.
