I am running a VRFID and also have a wet NOS system with a 50hp shot. This has been a proven combo. After a dyno run I removed the motor to have the trans gears back cut. I also pinned the mains while I had it apart. It went back together very smooth. Since then the nitrous hasent worked. The bike runs fine on just motor. When the nitrous kicks in it falls flat on its face.
I have tested the system on the lift and it is working. It does seem that it isnt fogging like it should. I have checked jets and lines for obstructions etc. still with no luck. Changed solenoids etc. I figured I would post up and see if there is a member that may be able to suggest something that I may be over looking. Any and all comments appreciated.
