V-Rod "Nightrod Cowl" Kit
Mounts are in Stock NRS "Cowl" from HD may take a week to get!
We've taken the 2007-2011 Nightrod Special "Cowl" and have adapted it to the "Inverted Front Forks" of the 2012 and Up V-Rods and Muscles.
This is a very popular look for the Nightrod!
Customers were disapointed that they didn't get the Cowl on their newer V-Rods, and Now you Can!
The Method of Securing the Fairing to the Headlight Mounting Area where the top triple tree mounted when you take your Stock headlight off.
By using our Custom Made Headlight Mount you can attach it to the Top of the Triple Tree and also mounts below the Lower Triple Tree for a Strong Mounting System to Reduce the Vibration of the Headlight with the Hardware provided.
The "Slotted" Hole is Adjustable for your Headlight to Raise it or Lower it for your Preferred Location!
The Basic Kit will Include the Powder Coated Black Mounting Bracket & Mounting Hardware.
You can Order the "Optional" Nightrod Cowl and Backing to hold ANY 5 3/4" Bulb in place!
http://www.grcustoms.com/shop/index.php?route=product/product&path=297_332&product_id=1956
I already purchased my GR headlight mount (1-0054-MAA) to install the HD daymaker LED. I'd like to get the cowl too.
Will the cowl attach to this mount?
Looking at the options on your site, am I just eliminating the mount option?
Thanks!
No, it's a different mounting system but you can still use that mount you have you'll have to get a taller Post it will be too low on the bike if you don't
