Dose anyone know if you can install a 2015 night rod radiator cover on a 2015 muscle F?
"Vrod King"
Yes you can. You can even go the other way by putting a muscle radiator cover a DX for a different look.
Mike thanks for the reply, can you install the Radiator Shrouds from a Vrod night rod VRSCDX on a Vrod Muscle VRSCF. Or do you need to install the whole assembly? Will the assembly that is already installed allow me to just take off the muscle Shrouds and install the night rod slimmer Shrouds or will I need to install the night rod assembly also?
Thanks for you help...
"Vrod King"
No you don't need to change the radiator and oil cooler. They are the same. Just change the shroud to the one you want.
My '09 AW runs a muscle shroud instead the one it came with. Some guys know something is different but can't figure out why mine looked different from others.
