1 - 7 of 7 Posts
I have a 2012 special night rod and the two blocks of the engine are broken... the question is....
Can I use a 2006 vrod engine?
"Vrod King"
Simply answer is yes, you can make anything work. But then you are going from a 1250 down to a 1130. I would keep a eye out for a later 1250 instead.
VRSC est -03
1250 vs 1130.
Some minor issues as belt pulley / # teeth, stator/plug/connector, length pivot spacer.
Also - if needed - this is the time for new rear engine rubber mounts!
How did you manage to break the cases? Wheelie? Rock?
1250 vs 1130.
Some parts inside went lose and brake
1 - 7 of 7 Posts
