1 - 12 of 12 Posts
Just got a 2002 vrsca, the bike was sitting for 6 years, I got new battery and put fresh gas, but won't start, the pump is not making any noise and I checked the two wires and I get no power, any idea? Your help is appreciated
I checked the fuses and managed to get power to the fuel pump, I disconnected both fuel hoses and try starting it, no gas comes out of the hoses, my guess is that the pump ceased, I blew air in both fuel connections and only the smaller one is clear but unsure if the other side is one way out.
Thanks
Do you know why it was sitting for 6 years?
Asatruar
On the 2002 VRSCA , (and other models up to at least 2006), the fob does not act as a "proximity switch" like the later models. So the fob battery being dead doesn't rule out the bike from running.
Though if the Security system was installed;(it was an option on the early US models) & one desires to use it, a fresh battery in the fob likely is a good idea.
Asatruar
Mine's an '06. Fob has a button you need to press to arm/disarm the security.
Welcome! Sounds like you have a bad fuel pump. When key is on and run/stop is in the stop position turn it to run and listen for a humming sound. If it humms like a electric motor running for 2-4 sec. then fuel pump is working.
1 - 12 of 12 Posts
