I have an 03 V-Rod custom converted to a bagger. I put a Corbin dual seat on it, but still need about another 2" of setback for the handlebars to be comfortable. I can't find a set of risers that will replace the stock set to move the bars back. Anyone have any options that won't require replacing the the brake and clutch lines?
AIM Bagger Edition
Norm welcome to the Forum. Very nice looking ride.
If you changed your risers to a set from a B model it would give you a ton of handlebar options. The bars and risers that you have now are combined, with the risers welded to the bars. There are only 2 types of bars for this set up, stock and drag bars.
The swap to the B riser is very easy to do. You can switch to a B model riser that comes in grey and then decide on whatever pullback for bars that you want.
Post a request for the B model risers in the wanted section, I'm sure you can find a used set here.
They're was a reduced reach bar set that I have, it was available the 1st few yrs and it gives you another inch of room.
