1 - 3 of 3 Posts
Come back Max
Okay chaps.
Apparently the speed recalibrator simply plugs in between the pickup sensor and the stock wiring harness. Okay but where are they to be found?
I look at a wirering loom and freak out.
PLEASE HELP!
SNAFU
Vincent,
The speed sensor is located on the top of the transmission. It's held in by a Hex head bolt. The 3 wires are separate from the rest of the wiring and come up the frame and directly over the rear coil pack into a connector on the frame cross member under the fuses.
Here's the wiring diagram.
Come back Max
mjw930 said:
Vincent,
mjw930 Your a good man! :thumb: (I'm assuming mjw is male?) :hmm:
Anyway thanks a lot whatever your gender!
1 - 3 of 3 Posts
