Found new Throttle Body on ebay for $125..............Thanks for all your help!
Anybody have a stock TB for my bike?
There is a chance I won't need it but I want to start the search now just in case.
I took the IAC off to check it and broke the head off one of the IAC bolts because Harley practically welded the bolts in the unit with thread lock. If that wasn't bad enough, an easy-out then broke off in the bolt after I drilled it and the easy-out metal is so hard I haven't found a drill bit that will drill through it so I can try again (Venting)!
If you have one let me know. I hope to find a newer one that is still fully assembled with the IAC and all attached.
Thanks!
Thanks!
