Greg/Moderator
I need part#'s for 03A
Connecting rods
Head bolts
Stock main and rod bearings
Thanks Greg
24307-01K: connecting rod with bolts
984M: main head bolt
1017M: 5 mm hex key head bolts (long: 6 mm X 1.0 mm X 95 mm long)
966M: 5 mm hex key head bolts (short: 6 mm X 1.0 mm X 35 mm long)
24312-01K: thrust bearing
24409-01K: main bearing shell, red: alt. side min=55.984 mm, max=55.990; clutch side min=55.959 mm, max=55.965
24410-01K: main bearing shell, green: alt. side min=55.977 mm, max=55.984; clutch side min=55.952 mm, max=55.959
24411-01K: main bearing shell, blue: alt. side min=55.971 mm, max=55.977; clutch side min=55.946 mm, max=55.952
24412-01K: rod bearing shell, red: min=47.983 mm, max=47.991
24413-01K: rod bearing shell, blue: min=47.975 mm, max=47.983
Greg/Moderator
Thanks Steve
Looks like 2 different size head bolts, do you know how many of each of the head bolts ?
Greg/Moderator
Just got off the phone with Hales HD, I have a parts book coming to replace the one I can't find......:hidesbeh:
head bolt count
The parts book is confusing on these bolt counts. According to the Service Manual there are four main bolts, and two long and one short of the smaller head bolts on each head, i.e. 984M (8 total), 1017M (4 total), and 966M (2 total).
I haven't removed my heads to confirm this so someone else may need to post to give you confirmation. HD publications are not edited very well and I wouldn't trust what is printed in either book (I hope the part numbers and sizes I copied from these books are correct).
