1 - 2 of 2 Posts
Hi Guys,
I have a 02 V-Rod rolling chassis with no motor and I was wondering if a 07 motor will fit bolt on in the frame with the engine support ?
Any advice will be appreciate
Thanks
Ray (vrodcustoms) has a thread on here about what needs to be done. The newer engines use a different lower engine mount so you'd have to get the necessary pieces to make it work on the '02 chassis. You may have to change the rear swingarm too. Other than that everything else is the same I believe.
1 - 2 of 2 Posts
